I have been using a hub in my van, and while in the Canary Islands, I created a routine to turn on the inverter and the fan every day at 7am. However, when I returned to mainland Spain, I paused the routine. Now that I am back in the UK, I have deleted the routine, but the inverter and fan have been turning on every day at 7am for the past month. I'm not sure what to look for since there doesn't seem to be anything there.
This is multi end point swaitch x 4 all others are working ok.
switchon Inverter was turned on DEVICE Switch 1
When Inverter turns on, turn on Inverter Fan (basicHandler)
Google Home (stateChangeHandler)
2023-04-24 07:00:01.678 AM UTC
switch on Inverter was turned on DEVICE Switch 1
dev:1382023-04-24 08:00:01.677 AMinfoInverter was turned on dev:1382023-04-24 08:00:01.677 AMinfoInverter was turned on
dev:1382023-04-23 09:57:46.919 AMinfoInverter was turned off
dev:1382023-04-23 09:57:46.916 AMinfoInverter was turned off
dev:1382023-04-23 09:51:35.390 AMinfoInverter was turned on
dev:1382023-04-23 02:00:56.878 AMinfoInverter was turned off
dev:1382023-04-22 11:59:55.062 AMinfoInverter was turned on
dev:1382023-04-22 03:12:44.987 AMinfoInverter was turned off
dev:1382023-04-22 03:12:44.984 AMinfoInverter was turned off
dev:1382023-04-21 11:20:00.209 AMinfoInverter was turned off
dev:1382023-04-21 11:02:18.946 AMinfoInverter was turned on
dev:1382023-04-21 04:25:35.721 AMinfoInverter was turned off
dev:1382023-04-21 04:25:35.721 AMinfoInverter was turned off dev:1382023-04-17 08:00:03.584 AMinfoInverter was turned on dev:1382023-04-17 08:00:03.584 AMinfoInverter was turned on
Checked google home nothing there nothing in the admin that i can see in hubitat
Dashboard
Google Home
When Inverter turns off, turn off Inverter Fan (Basic Rule-1.0)
When Inverter turns on, turn on Inverter Fan (Basic Rule-1.0)
I checked both google and "When Inverter turns off, turn off Inverter Fan (Basic Rule-1.0)" there are no time just a simple turn this on when this is turned on/off
So there's definitely no Google Assistant routine that may be doing it at 7am?
AFAIK, Google doesn't have a "Hunches" feature (like Alexa), so it would have to be a routine you created at some point. Long shot, but worth ruling out.
I think Routines are managed from the Google Assitant app (not the Google Home app), but that may vary by Android or Apple - I'm not sure.
Go to the device page. Select Events. Find the entry for it turning on. See what shows in the "produced by" column. That will tell you what turned it on.
