In the apps I have installed the remove button does nothing. For instance in "Button Controllers" I have one named delete when I go into it the Remove button is red and does nothing.
have you tried restarting the hub for it to rebuild the database?
Shutdown Hub and Reboot Hub also do nothing. Can I just unplug it?
Do a shutdown first or you could corrupt the database
How do I do that? Sorry newb
Thank you I push that and it does nothing.
I think the button is always red? Most apps are anyway. I don't think that is why it is not removing.
Maybe a browser issue? Did you try using private mode or a different browser?
Thank you... But I am using the app.
Try using a browser to connect to the Hub, instead of using the Hubitat Mobile App. Just as a test to see if anything changes.
What app is it that you are trying to remove?
That worked thanks Rebooting now
BOOM!!! Working now after the reboot!!! Thanks!!
