According to the error, you’re probably entering http://[hub IP address] in your browser but the hub is configured to require https://[hub IP address].
What exactly are you typing in to browse to you hub?
I admittedly do not know how the browsers on Iphone work. But, on Android, there was a setting in Chrome and chromium based browser that prevented users from opening "less secure" addresses that you had to toggle off. While they could very easily know that these are local addresses, they choose to either block all http, or allow all http, or make you create a list of safe addresses.
In any case, google says: For iPhone or iPad (iOS 18+):
Open the Settings app on your device.
Scroll down and tap Apps, then select Safari.
Look under the Privacy & Security section.
Toggle OFF the switch for "Not Secure Connection Warning".
Force close Safari and try opening the link again.
Still not working? Clear HSTS Cache
If the setting is turned off but the error persists, Safari may have cached a permanent secure rule for that site. [1, 2]
Go to Safari > Settings > Privacy and click Manage Website Data.
Search for the domain or IP address you are trying to visit, select it, click Remove, and try reloading the page.
Do you recall if you previously configured the hub to accept HTTPS only connections from the hub’s network settings page?
That’s what the text of the error would suggest.
I’m not sure why the app wouldn’t redirect to an HTTPS connection automatically if that’s the case, but someone can probably look into that if that’s in fact the issue.
I think that would result in a different error than what the OP is seeing. The connection to the hub is occurring, but it’s being refused due to an SSL issue.
If the IP address had changed, there would be no connection at all.
