I'm using Joel's GE Enbrighten ZW+ Dimmer driver on a Honeywell zw+ dimmer. Setup a Rule Machine app to set the dim level to 100% on a double tap. All works fine. Now I'm wondering has anyone created a rule where a bottom tap turns the light off and then a single tap turns it back on to the previous dim level that it was set at before double tap set it to 100? Like saving the current dim level during a double tap in a variable specific to the switch? And then restore the dim to that level if the variable is found when single tap happens again? Not too familiar w/ Hubitat rules yet but being a programmer, I'm hoping something like this is possible. Any suggested steps or general outline appreciated. Thx
Let me get your goal straight here: Say the light/switch is already on at Level A. You want a double-tap (up) event to brighten the light to 100. Then the very next tap (up) event – whether the light remains on or has been turned off in the interim – should return the light to Level A.
Is that correct overall? Also, have you checked Logs or the switch's own Details page to determine what PUSHED or DOUBLE-TAPPED events are assigned to those particular actions?
Basically, though I figured one would hit off (bottom tap) in between if that made for a better algorithm as not having looked at that in the logs, I'm not sure if a single top tap event would register if the switch was already on. Thx
That's why I suggested looking at the switch's Details Page (better yet Logs > Live Logs) to see for yourself whether an event is registered by tapping up once AFTER you had tapped twice some seconds earlier. Lemme know. Because if so, I have a rule in mind.
Thx. Will do. Got wrapped up into some other things since we just moved but will hopefully be able to do this soon.
And I know this has nothing to do with your question but, Zooz dimmers have this functionality built into the firmware. The double-tap level and single tap level are each configurable. The non-smart Lutron Maestro dimmers work the same way as well (sans configuration).
Switch is a ZW+ Honeywell Smart Dimmer [ZW3010] running with Joel's GE Enbrighten ZW+ Dimmer driver.
Here are live logs doing an Off, On, Double tap, On [where I use the Rule Machine to set the level to 100% with a fade of 4 for double tap]. On event indeed happens while the light is already on at 100% after the double tap!
dev:52023-03-15 11:09:13.117 PMinfoDave's Bath is 99%
dev:52023-03-15 11:09:13.112 PMdebug---SwitchMultilevelReport V3--- Dave's Bath sent SwitchMultilevelReport(value:99)
dev:52023-03-15 11:09:13.108 PMdebugparse description: zw device: 0B, command: 2603, payload: 63 , isMulticast: false
dev:52023-03-15 11:09:13.090 PMinfoDave's Bath turned on [physical]
dev:52023-03-15 11:09:13.089 PMdebugPhysical ON Triggered
dev:52023-03-15 11:09:13.087 PMdebugCentralSceneNotification V1 Called.
dev:52023-03-15 11:09:13.084 PMdebugparse description: zw device: 0B, command: 5B03, payload: 1F 80 01 , isMulticast: false
dev:52023-03-15 11:09:06.776 PMdebugsetLevel(value, duration) >> value: 99, duration: 4
dev:52023-03-15 11:09:06.773 PMdebugsetLevel(100, 4)
dev:52023-03-15 11:09:06.569 PMinfoDave's Bath had Doubletap up (button 3) [physical]
dev:52023-03-15 11:09:06.568 PMdebugDouble Tap Up Triggered
dev:52023-03-15 11:09:06.567 PMdebugCentralSceneNotification V1 Called.
dev:52023-03-15 11:09:06.562 PMdebugparse description: zw device: 0B, command: 5B03, payload: 1E 83 01 , isMulticast: false
dev:52023-03-15 11:09:06.560 PMdebugThis does nothing in this driver, and can be ignored...
dev:52023-03-15 11:09:06.558 PMdebug---BASIC SET V1--- Dave's Bath sent BasicSet(value:255)
dev:52023-03-15 11:09:06.542 PMdebugparse description: zw device: 0B, command: 2001, payload: FF , isMulticast: false
dev:52023-03-15 11:09:01.075 PMinfoDave's Bath is 99%
dev:52023-03-15 11:09:01.070 PMinfoDave's Bath was turned on [physical]
dev:52023-03-15 11:09:01.067 PMdebug---SwitchMultilevelReport V3--- Dave's Bath sent SwitchMultilevelReport(value:99)
dev:52023-03-15 11:09:01.062 PMdebugparse description: zw device: 0B, command: 2603, payload: 63 , isMulticast: false
dev:52023-03-15 11:09:00.142 PMinfoDave's Bath turned on [physical]
dev:52023-03-15 11:09:00.141 PMdebugPhysical ON Triggered
dev:52023-03-15 11:09:00.140 PMdebugCentralSceneNotification V1 Called.
dev:52023-03-15 11:09:00.136 PMdebugparse description: zw device: 0B, command: 5B03, payload: 1D 80 01 , isMulticast: false
dev:52023-03-15 11:08:54.258 PMinfoDave's Bath was turned off [physical]
dev:52023-03-15 11:08:54.254 PMdebug---SwitchMultilevelReport V3--- Dave's Bath sent SwitchMultilevelReport(value:0)
dev:52023-03-15 11:08:54.251 PMdebugparse description: zw device: 0B, command: 2603, payload: 00 , isMulticast: false
dev:52023-03-15 11:08:53.303 PMinfoDave's Bath turned off [physical]
Okay, so here's my thought process... since the switch broadcasts (and more importantly, HE sees) the "On" event after the light has already been turned "On" or brightened, we can leverage that in a Rule Machine rule, as follows:
TRIGGER
Button: Dave's Bath == 3
ACTIONS
Capture: Dave's Bath
Wait for Event > Dave's Bath: On
Restore: Dave's Bath
The only major stumbling block I foresee is if this Rule can't perform its Capture ahead of your DoubleTap handler doing its thing (raising Level to 100), then we'll have to involve Hub Variables, and construct a virtual capture from scratch.
P.S. Absolutely all of this could (perhaps even should) be done in Button Controller. As your button-related workflow grows more complex, BC wins over RM.
Thanks for the ideas. I'll read up on the button controller. Does button 3 mean the upper was double tapped? Again, may be a while, but I'll eventually post back what I figure out and tried.
Yep, the numbering scheme is pretty typical across most devices (e.g. toggle switches), so that's why watching in Logs is so helpful. For example, my GE/Jasco in-wall switches map out thusly:
1 = On (tap up) , 2 = Off (tap down) , 3 = (double-tap up), 4 = (double-tap down)
I use those designations to my advantage in Rule Machine or Button Controller app, particularly if I want to associate buttons 3 and 4 with routines (such as an auto-off fan timer, or sending commands to Alexa while I shower, etc.).
