Can I get dumb LED to dim very low with Inovelli Gen 2, LZW31-SN Leading Edge dimmer?
All of my dimmers are Inovellin Gen , LZW31-SN, which are leading edge, and does not have a parameter to switch to trailing edge, as far as I can tell from my search today on their web site. I know LEDs often want trailing edge, but I'm not going to just swap out my 20+ switches for that. The lowest I can dim is about 25%-35%, using mostly Ecosmart 60W, 5000K, 840 lumen bulbs. My wife likes them normally really bright and daylight so I'm looking for similar specs.
I also don't know if it is possible with dumb LEDs, but can any that get that bright be dimmed low enough so they get that orange-like glow of an incandescent?
Philips Warm-Glow (dumb) bulbs move their CT lower/higher as you dim/raise respectively.
This is just a property of how the incandescent filament glows, not the light level per se. In the early days of LED bulbs, I remember some manufacturers touting the fact that their LED bulbs don't do this (i.e., that they do maintain a constant color temperature as you dim) as a feature. What you're really looking for isn't something that can dim low per se but rather something that intentionally simulates this behavior (and, I suppose, can dim however low you need).
The above from @hydro311 is the only one I've heard of, but I'm about all in on smart bulbs at this point (certainly another option, probably not the cheapest) so I haven't looked in a while. In any case, if you search for something else, it may be helpful to keep on mind what you'd actually want to look for feature-wise, so hopefully that helps! You aren't likely to find many since, again, this is a feature they'd need to bake in, unlike incandescents, where it just happens.
The buzzing on low levels with those bulbs on LZW31-SN is a real buzz-kill ... LOL (though they buzz a lot less than others)
Not for dumb dimmable LEDs. Temperature stays constant through the dim range. Don't know about your dimming switches. But the ones I use, the driver has a min dim level needed to get them to glow at all. That exact setting depends on the LED devices. But I find that setting to be 18 to 22%. That sets the 1% level for normal dimming. For which can be so low I can see a glow only in a dark room. So check your driver and is it has it, set the minimum to what ever you want and that will become the 1% dim level for your actions.
