I have two C8 hubs and often need to bounce between them.
It would be great if they were visually distinct from each other.
Is there a way to make the web menus a different color from each other?
For example if the first one was the typical green color and the second hub used red highlights?
If there's something in the settings, I've missed it.
Much appreciated.
KC
If you use Chrome, there is an extension called Color Changer. It seems to work by IP or hostname, so you can change color on the pages for one hub, and keep it different than the other.
thank you! i have one web site that I like, but with black brackground that drives me crazy, was looking for elegant solution long time and now changed it easy to normal for me.
