One option to adjust temp and color would be to create a rule that runs before your wake time that sets those presets to the values you want on power up.
I have a rule that resets all bulbs to 100% brightness at 10am daily but the lights do not power on at that point.
Unfortunately, it is not possible to preset brightness or color temperature on a Hue bulb without it also turning on.
So I'd need to have all my hue bulbs flash on at once to do the update like you're described.
You can set color and set level with Hubitat without turning on the bulbs.
Level preset and color preset. My recollection is that was not available for all bulbs from all manufacturers. It's been a while since I've set up any new ones so that may have changed.
This is for Hue as Hue is the scope of the thread.
how so? when setting color temperature or level from the bulb driver page in Hubitat the device always turns on.
I checked the relevant Hue documentation for the underlying event in the Hue Hub API and it indeed mentions that any adjustment of CT or Level implicitly has a "on" event attached as well.
Just thinking out loud here but have you tried pairing a Hue Bulb directly to the HE hub instead of the Hue Hub and using the Hue integration? I used to have a couple of Hue Color Bulbs directly paired to HE and if I remember right, I could pre stage the color before turning it on but not 100% sure about this.
Would not hurt to try because this might just be an API limitation and not a buld limitation.
This isn't completely correct. If you send the command via APIv2, you can send the color temperature with the command off. @bertabcd1234 actually posted earlier how it works with on command:
You would just tweak the command to be off instead of on.
With the above said, for Hue bulbs on a Hue Bridge, the "better" way is to create a generic scene. Then use Hubitat to update that scene with CT/Brightness as Day Lights progresses. When you are ready to run your automations, you just turn on the scene. The bulbs all respond at the same time and then Day Lights takes over.
I know this isn't what you want since you want a Man-in-the-Middle approach that Hubitat does not provide, but these are both ways to make it work (at least in a Hubitat environment).
Interesting I will have to see if a Hue bulb integrated through Home Assistant or directly to Hubitat has prestaging. This would get me closer to my goal and may end up using it as a short term solution. Long-term I'm still pursuing a move to a HA based solution since I believe "command handling" to allow applications to customize incoming commands is a very desirable feature, particularly for device that behave differently than normal.
e.g all the weird LiFX behavior in DayLights could instead live in a custom LiFX command fixing app, and DayLights could focus on what it's good at instead of per-device fixes.
It's interesting since the SmartThings platform had command handling in some form based on a thread I found here: subscribeToCommand? Listening for deviceNotification() on a childDevice Can't confidently say that the SmartThings implementation would have allowed a fix, but it's disappointing that Hubitat opted not to included it when forking ST APIs.
There are always unspoken caveats with these workarounds like scenes.
If I have Day Lights (or whatever automation) controlling a Hue Scene, it will always be controlling all the lights in that scene. I wouldn't have the ability to override the dimming on a handful of the lights within the scene, as soon as Day Lights ran next, those lights would snap back to the Day Lights controlled state. If I could use scenes without losing granularity of control I would.
This is a real lamp firmware thing as much as an app thing. Most Hue bulbs (and a lot of Zigbee whites) power on to the last on-state, then accept CT/level. If the controller sends On first and setColorTemperature a few hundred ms later, you get that bright/old flash. HA Adaptive Lighting intercepts turn_on and stuffs ct+bri into the same payload so the lamp never shows the old state.
On Hue via the built-in bridge integration, setColorTemperature with a level already turns the lamp on in one command. The trick is to stop the voice path from emitting a bare On. If Siri/Google maps to the Hubitat On capability, Hubitat will honk that On to the bridge before your piston/RM can rewrite it. Workarounds that actually look decent: (1) expose a virtual switch that only ever sends setColorTemperature(kelvin, level), never On; (2) Hue v2 API prestaging if CoCoHue/built-in supports startBehavior / power-on preset on the device; (3) keep adaptive CT in the Hue app/bridge as the default power-on, and let Hubitat only dim/off.
Scenes are ugly for voice, agreed. One virtual per room that always does setColorTemperature is cleaner than a scene farm.
If users are having Hubitat be in the middle (i.e.) they are sending their Hue bulbs from Hubitat to their voice assistant, there is a fairly easy problem to solve with a custom app. It's not about intercepting the On command. It's about creating an app that sends the setColorTemperature command to the bulbs that excludes the On command. This implementation would set the bulbs to the correct color temperature. That way when someone uses a voice assistant, the On command is already correct. Then the built-in Adaptive Lighting or user custom circadian lighting can take over.
Personally, I solved this using CoCoHue and both Hue scene types (regular scene and their Smart Scenes) with a custom app. I view Google Home as a manual override (my bulbs are connected via Matter directly). This way, if my family uses Google, they set the lights directly; otherwise, all automations and Hue devices (motion sensors and buttons) point to the modified scenes.
