Can a Rule alter a "repeat every (XX)" dynamically while repeating
Lets set a repeat in motion.
Base setting is Repeat every (XX) seconds.
Pick an event, an additional light bulb color for example.
XX=XX+1
light bulb color no longer needed.
XX=XX-1
Will the repeat loop dynamically adjust the repeat time?
Thank you for your thoughts on this subject.
Frank.
Yes.
Thank you!
