[C8P - ZWJS - 2.4.4.151] Trying to update a Zooz ZSE41's Firmware
I get an error saying "The transferred image does not match the Firmware Target"
It is included as "S2_Authenticated" and LR.
Most of the topics relating to updating the firmware predate ZWJS and LR.
Any suggestions on how to update this?
@agnes.zooz
I was able to update my 3 41s to 2.30 back when it was first released, so there's not any issue on Zooz's side -- there's no reason to tag Agnes about this.
My 41s are all paired LR, but I don't recall if I hopped over to JS to do those updates or if I did them from ZIP.
The firmware update process can be very finicky with battery devices in particular -- timing the device's wakeup to catch the update request can take some trial-&-error, but it is definitely possible.
I remember seeing threads/posts around here that aren't too old and have some updater-related lessons learned and tips & tricks to consider.
That’s helpful to know it’s worked on LR devices. I’ve been trying during manual wake-ups but keep hitting the same error, did you have to exclude/include again or just retry until it caught at the right time?
Make sure you're clicking the right buttons!
It's happened to me before!
edit: Also, doesn't the firmware update only work on mesh-paired devices? I think I had to go back to mesh temporarily when I updated my 41s.
edit2: That was on ZIP as I recall. I'm finally on ZWJS, so forget what I said.
Mine downloads all the packets, then it throws the error.
I tagged @agnes.zooz because their documentation may be a bit dated. One of the links points to a dead "docs.hubitat" URL. The others seem to be referring to pre-LR, pre-ZWJS things.
Just wanting to make sure I'm doing the right thing for the newer things.
