[C8P-2.5.2.139] Ghost Actions
Just wondering if anyone else has noticed switches turning on un-commanded?
I woke up today and one of my attic lights had turned on. I was in bed at the time, so I certainly didn't turn it on (nobody else is here, so unless Casper got started ghosting around early, I have no clue what happened).
I ask, because I seemed to see something similar happen to another bulb a week or so ago (but I didn't bother to look at the logs that time).
The event logs seem to show a "physical" on (theoretically, that should only be from the device itself).
Note: In this case, I didn't actually look at the light (it's up in the crawl space). But, was notified that it turned on, so I turned it off.
As this was a random event, I don't have any good logs right now--just wondering if anyone else had seen such a thing.
A few years ago I had some random things happen because of a bad Zwave device. Not sure if that’s your case but worth pulling up the Zwave logs from settings and let it stay open for a while to see if you have a device spamming the mesh
Is Alexa Hunches still a thing? I see the Amazon Echo skill there, so I assume you are connected to Amazon/Alexa.
I've done my darndest to get THAT nonsense stopped. Those are the most annoying things. :face_with_symbols_on_mouth::face_with_symbols_on_mouth:
A "physical" on usually means the device itself reported the change, not that the hub sent a command. So I'd look outside the rules first.
  • Did anything else blip at the same time? A short power dip can make a smart bulb boot back on with its power-on setting.
  • Check the device page "In use by" list. An old test rule or app can still be holding it.
  • If it's a smart switch, a failing device can report presses that never happened. Worth watching if it's always the same one.
If it happens again, grab the device events and the hub logs around that minute. Matching timestamps across devices points to power. A single device on its own points to that device or a rule.
I wrote up the usual suspects for lights that turn on by themselves here: www.homeautomationcookbook.com/articles/lights-turning-on-by-themselves.html
Thanks.
Thus far, this was the first time for that device. An Inovelli dimmer switch (Z-wave dimmer).
No rules turning it on, no motion sensor, nobody near it. It just registered being on physically.
I had another light (zigbee RGB bulb) that I saw on the other day when I didn't know why, which is why I asked.
I'm going to be paying closer attention now.
I guess it is close to Halloween, so ghosts for real??? :stuck_out_tongue:
