Everything is Zwave. They are light swithes from Jasco/GE, Minostan, thermostats from Honewell, lock from Schlage, similar to my other house which works fine.
When I say everything stops, I mean that I can no longer control any device from the app. The current state is correct because the command doesn't work and therefore the state doesn't change.
If I operate the device manually, the state in the UI doesn't change. Even if I hit poll or refresh, it doesn't update.
This is the part that is most confusing. When I looked at logs yesterday, the last reboot recorded was on October 26th. And everything since, looked as if it has been working, with the exception that your hub was reconnecting to the network every hour. I've never seen this inconsistency before, but will check your logs again today.
Since you mentioned issues with Z-Wave devices, I see that you are not running Z-Wave JS. Can you switch to JS and see if that fixes your Z-Wave problems?
That seems to have done the trick. Switching to Z-wave JS seems to keep the devices working without rebooting.
that brings up a new question. After switching to JS, the hub interviewed all the devices. It seems to have found all of them. But it also found an extra device. In other words, there is some device that it is not able to interview. All the Z-wave devices seem to be properly accounted for already so I can't tell what the extra device is. Any ideas how to identify it? Is it a rogue device or some kind of secuirty backdoor that I stumbled upon?
You probably have a ghost, in other words a failed pairing attempt. Is the device right below the "ghost" node the same type? Say if ghost node #10 is a Multilevel Power Switch, is #11 a real device that is a Multilevel Power Switch?
Ghost nodes can cause a variety of Z-wave issues, typically slowdowns or delays in device activation, but there could be other symptoms. I don't think that this ghost is causing a lockup, but it would be good to remove it anyway.
Glad ZS is working for you. That said, curious as to how you tried to contact support in the first place? Did you send an email to support@hubitat.com or did you go through the web site?
Attempted to access support via website but no one every responded. Next opened warranty claim on website but no one responded. Opened a 2nd warranty claim on website and received an email with generic reply about responding. Then I emailed a few times from the initial email without luck until I complained on the community forum and heard back on this thread
