C8 hub will hang up for a minute when I execute "Leave" scene
Hello, I'm running 2.4.0.145 on C-8 Pro.
When I execute "Leave work" scene on homekit system have to switch off multiple zigbee lights (around 10), set aircons to off (via homekit) and by doing this hub is not responding for around minute. I measured ping's to it and looks that its loosing network communication of both ethernet and wifi interface (or it's so busy that its not answering for ping's).
After 30-60s everything works again.
Do not connect the hub on both Ethernet and Wifi. Disable the Wifi.
Turn on logging for you rule or whatever is running when you run that scene in HK.
Then post a screenshot of the Rule / App and also a screenshot of the logs from when it runs.
Ok, I turned wifi off and seems that problem is gone. I will observe for next days.
