C8 2.3.9.197
@bobbyD
The first 3 lockups were with earlier firmware versions.
Symptom:
Hub green light is illuminated. Will absolutely not connect normally or through any port. When power is removed the hub works on repowering.
Hub is wired to Router.
Hub was put into service in March 2023. Has been solid since then.
Have already:
- Changed Power adapter and cable.
- Removed Webcore
