C8 Hub Freezes
Hi All,
I have an issue with my C8 hub freezing, or becoming unresponsive. Hub is running latest firmware. This hub only used for radios, both zwave and zigbee and have nothing else running, as im using my C7 hub for all the apps, integrations, automations etc. Altogether this hub has 82 devices between zigbee and zwave (39 zigbee, rest is zwave). I now had at least 4 or 5 instances when the hub became unresponsive. Several times it was competely frozen as i coudnt even get to the diagnostics page and all the linked devices reported as OFFLINE in my C7 hub. The last time, which was yesterday, i was no longer able to open the UI, however was able to connect to the diagnostics interface to initiate a reboot.
As far as the device for zwave, its a mixture of different powered and battery devices, few are old non zwave plus devices for which i have zwave polling enabled. Also, 6 of the zwave deivices are kwikset locks, running S0 security. All of the zwave device always show a checmark in the status column and i have not seen any be offline at any time as i do think my zwave mesh is pretty strong. For zigbee, its also a mixture of powered and battery devices, more than half being moisture sensors. I do have an issue with only the leasksmart sensors drop intermittently, which im trying to figure out, but im adding additional repeaters there, so hope that will improve that mesh.
At this point, i have no idead whats causing these hub freezes and i dont seem to see anything relevant in logs when it happens, so i need help to try to figure this out. Thank you all in advance.
