All of a sudden I’m getting some very weird behavior with my C8 hub. I first noticed that my Hue motion sensor in my front hall was turning on when it detected motion but wouldn’t turn off by itself after the 2 minute timeout I had set months ago. I thought it might be the battery, so I changed it. That didn’t fix it. I then went to the Hubitat app on my iPhone and found I could turn it off that way. Before posting anything here about it I wanted to check the logs. But I couldn’t get to the logs. I then tried getting to apps and devices, etc. with no results. But I could see and control devices on my iPhone. I then went to https://findmyhub.hubitat.com. I was able for it to find my C8 using the MAC address, but when I clicked to connect to the hub it never did. I noted the ip address it reported (which matched what I had and matches what my TP-Link Deco app says it is) but it couldn’t find it that way.
What is also strange is that I can get to my classic dashboard on a browser, but no where else. I can get to both my classic and EZ dashboards on my iPhone. What is also strange is that one switch that is only connected to the ground line and neutral, and controls other devices won’t work, but other switches that are similarly wired (i.e. don’t directly control a device) do work.
I’m using a Mac Mini M5 Pro. I tried Safari, Chrome, and Firefox with the same results.
I certainly don’t want to just pull the plug on the C8 but I don’t know how to gracefully shut it done if I can’t connect to it.
Please help.
