[C8 2.5.0.143 ] ZEN58 Error Setting Preferences
I get an error setting preferences and ZERO logging no matter what I select for the logging level.
This happens with a virtual device AND both real devices.
I'm on the latest production release.
Thoughts?
@bcopeland @bobbyD
Any unusual setups, like VLANs or a reverse proxy you might be accessing your hub through?
I also always suggest sharing the actual hub platform version, which you can find in Settings > Hub Details.
Nothing unusual.
Please read the title, where I included the version.
Hub reboot, different browser, or different device change anything? And is it just this specific device? Asking because it sounds like it could be except for the “virtual” thing (since a Z-Wave device wouldn’t be), so knowing this might help someone reproduce. FWIW, I haven’t seen this one (except in odd cases like the above).
EDIT: Nevermind, went playing with this particular driver for fun, and found something odd with the “Auto-Off Timer” preference. You might notice has a bit odd formatting — supposed to be a enum/dropdown like similar ones. I’m not sure if there’s anything you can do in the meantime to work around the error saving (leaving it blank?), but it should be fixed in a future release.
It's only that device driver (a system one).
It acts up with a virtual device using that driver and both of my ZEN58 devices.
Reboots, factory resets, all the same.
It also doesn't log anything ever.
But, the devices work fine and the preferences seem to save anyway.
Thanks!
