[C8 2.5.0.143] SmartStart With Multiple Hubs
@bobbyD
I have 3 hubs. I'm working on repurposing an older C8 hub. I reset the Z-wave and Zigbee settings, then did a soft reset (I got an error doing the full reset). I also upgraded to the latest release).
When I select that hub in the mobile app, then go to add a SmartStart device, it shows a bunch of devices for my MAIN hub. I went ahead and added one device to the list for my "repurposed" hub.
When I went into the repurposed hub and looked at the SmartStart list through the SmartStart Manager App, it had all kinds of devices in it that were on the main hub. I used that app to delete the ones that shouldn't have been there.
Was this something that didn't get reset when I reset the Z-Wave settings?
Thanks!
What kind of error?
They are cashed, I wouldn't worry. They are not saved in the hub's database.
I did the full reset. It ran a while.
Then said the reset failed.
I rebooted and it hadn't reset (it was several releases back).
I reset the zwave & zigbee radio/settings. And, I did a soft reset.
That is the same process the full reset does, plus removing the registration, which you can do from my.hubitat.com. Hard to tell why the macro failed.
Since I'm still using it, I'm fine with keeping the registration.
Curious about the smartstart list having all the devices (I'm guessing from when it was my main hub).
Thanks for getting back to me!
