UG my workhorse C7 hub from .141 to .153 this evening. First off I usually click on everything to see if it appears to be there. When I clicked on Dashboards I got an error 500,- then there was no response for a minute or so, then the hub rebooted itself. When it started again it had about 560,000 free memory, then in about 10 seconds it dropped to 296,000! It appears all is okay now, but I'm tempted to revert to my previous platform because of the low memory situation. My C4 and C5 seem to have done the UG fine, but they had been on something like .149 or .150 for a few days.
See bottom image - after 17 minutes everything seems to be settling down. I'm going to let it run until tomorrow and see how it is.
That's actually pretty normal preload apps on current version using the new java library. After several days the current version will hover between 240 and 260
Thanks for that Rick. I'm used to seeing 500 plus immediately after boot. Everything does seem to be working ok. My c7 will normally drop to under 200 in three days.
As long as it stays above 130, I probably wouldn't worry. One of the earlier ones had me down at 80 or so before I was getting warnings and yet everything functioned fine.
I create a text file which records free memory every hour. Its been months since my zigbee would shut down. So overall things are running very well. My c7 is heavy with rules and devices. It is an amazing little device. Seems to take everything i throw at it.
From a reboot at 9am on Feb 18th, to 8:30 am on Feb 23 the system performed better than ever. Memory stayed above 150000. I did see my zigbee devices and some zwave devices either reacting slowly or not at all this morning and so I rebooted the C7 which came up with 467928 free memory. It appears for me the critical level of free memory is around 150xxx.
Here's some of my logged memory status:
Feb-22-2023 at 11:00 PM C7-1 Hr Cnt: 107 - Free mem: 188936 cpu5Min: 0.14, cpuPct: 3.5
Feb-23-2023 at 12:00 AM C7-1 Hr Cnt: 108 - Free mem: 184648 cpu5Min: 0.16, cpuPct: 4.0
Feb-23-2023 at 01:00 AM C7-1 Hr Cnt: 109 - Free mem: 180800 cpu5Min: 0.16, cpuPct: 4.0
Feb-23-2023 at 02:00 AM C7-1 Hr Cnt: 110 - Free mem: 172924 cpu5Min: 0.13, cpuPct: 3.25
Feb-23-2023 at 03:00 AM C7-1 Hr Cnt: 111 - Free mem: 179344 cpu5Min: 0.18, cpuPct: 4.5
Feb-23-2023 at 04:00 AM C7-1 Hr Cnt: 112 - Free mem: 147184 cpu5Min: 0.21, cpuPct: 5.25
Feb-23-2023 at 05:00 AM C7-1 Hr Cnt: 113 - Free mem: 176020 cpu5Min: 0.15, cpuPct: 3.75
Feb-23-2023 at 06:00 AM C7-1 Hr Cnt: 114 - Free mem: 173476 cpu5Min: 0.14, cpuPct: 3.5
Feb-23-2023 at 07:00 AM C7-1 Hr Cnt: 115 - Free mem: 177132 cpu5Min: 0.14, cpuPct: 3.5
Feb-23-2023 at 08:00 AM C7-1 Hr Cnt: 116 - Free mem: 142692 cpu5Min: 0.15, cpuPct: 3.75
Feb-23-2023 at 09:00 AM C7-1 Hr Cnt: 117 - Free mem: 154872 cpu5Min: 0.12, cpuPct: 3.0
System has restarted at 09:35 on 2023-02-23 ....
Feb-23-2023 at 10:00 AM C7-1 Hr Cnt: 118 - Free mem: 467928 cpu5Min: 0.21, cpuPct: 5.25
