When I show the past logs on the new C7 hub I am not getting the labels for the devices.. instead I get this:
Note: the "Zooz Central Scene Dimmer" entry in the list (bottom pane) is the actual name of that device - I haven't changed it yet. All the other devices have labels associated with them...
Just to clarify - I tested on a Windows 10 laptop using Chrome, Edge and Firefox.. all report same.
This is correct, don't worry they will change. What happens is when it joins it creates the log with the current name. You then change it and create more logs but when you go to past logs it grabs the name of its oldest log. So once them logs have disappeared the log it grabs will be the new one. If you went to live logging and created a event it would show up as it's new name.
Sigh... I knew this and completely spaced out about it... Haven't set up a new hub in a while... thanks for the reminder..
Doh!
