Thank you for moving my post. I tried reading all of the other related posts and added my reply to the thread that seemed the most similar.
Hub model: C-7
Current firmware: 2.3.9.166
My C-7 hub has been operating extremely well since I bought it in Oct 2022, then in the last month or so, it started locking up intermittently--sometimes every day, sometimes every few days. When I say "lock up", I mean that the LED remains green, but the device does not respond to pings, and the diagnostic web pages via port 8081 does not load. Automations stop working. Only thing that can be done is to power cycle.
Firewall/network topology: Cable modem plugs directly into pfSense router, which then splits out via wired connections throughout the house to WiFi access points. The C-7 is plugged in directly to one of these access points via Ethernet. Jumbo frames are not enabled anywhere on LAN and also nothing has changed AFAIK with my home networking setup in the last month, so I don't see how that could explain the change. It doesn't seem to be a connectivity issue. The WiFi access points are rock solid and other devices plugged into it via Ethernet are working fine even when the C-7 does not.
Power is powered via the power supply and USB cable that came with the device when I bought it.
Devices: 16 Z-wave devices, 14 Zigbee devices.
User/custom integrations: I have Maker API installed, but I'm not actually using it at the moment. I use webcore quite a bit and have the AlarmDecoder service installed.
Past Logs: I can never see events far back enough to have any inkling of what's happening. I don't know of any errors being generated.
I have tried monitoring dbsize and memory usage--I currently have Pushover notifications set up if the RAM falls under 200MB free, but I have never gotten any such notifications.
Again, I just want to emphasize that everything about my C-7 has been perfect for the last two years, until about the last month or two ago. And last month I was out of town for most of that month, so I can't imagine what could have changed in our home when none of us were actually there. All my automations died while I was out of town and no one was there to power cycle the Hub.
Any advice you can offer would be greatly appreciated!
