C7 hub stopped connecting to devices
My C7 hub stopped connecting to all devices. I can access the hub, it shows my devices but won't connect to them. No change to IP, Firmware is the latest. It worked fine untill recently. Any ideas?
Have you tried rolling back to the last "good" f/w?
Yes I did. It made no difference. Went back to latest one.
In fact that was the version that was working.
What types of devices are these? Zigbee, Z-Wave, Lutron, Hue, …?
Are you seeing errors in your logs?
@user1007 Have you done a full power cycle? Shut down from the settings menu, then unplug for 5 mins and power back up.
Yes I have done a power recycle. I have also performed a soft reset and reload with no improvement.
I have a screenshot of error log but not sure if it is from the correct log.
UniConverter_20230315112402
Thanks! However, it looks like it uploaded at low resolution…
Hey Sebastien
Thanks for your help. After a shutdown and disconnect for about 30 mins. Devices are beginning to start working again. My two lights are working now and my other zigbee devices are not working yet so I am watching them. They are working in the Alexa app but not sharptools. I will start adding those devices to Hubitat soon.
Again Thanks for your patience and help
Cal
