Yesterday I noticed that one of my C7 hub was no longer accessible via web interface. I unplugged it and restarted it. The LED appeared as usual starting with blue then a green. Checking my router , the hub was nowhere to be found.
I connected this hub to another router (and another network cable) and after the Hub reboot, the router network map only showed my PC connected.
I tried the ipaddress:8081 but there is no connection to be found.
Am I to assume this hub (network interface) is dead?
Have you tried pressing and holding the Network Reset button on the bottom of the C7 hub for at least 10s? The LED should change color while holding the button, and the hub will reboot. Afterwards, the hub will request a DHCP address from your router, hopefully.
If that does not work, then make sure you try a different Ethernet patch cable and reboot the hub.
Also, for future reference, you should do a reboot with database rebuild since you did this. You may have already. But I did not see it mentioned. Unplugging while running can have an effect on the database integrity. The rebuild should fix that if it did happen (no, it is not always immediately obvious if there is or isn't database corruption)
Another point is the Network reset only resets the hub's network connection settings, doesn't touch anything else, mess w/your devices or automations, etc.
Well done to post that, helpful for many, but not helpful for people like me (visual forgetters).
