C7 and C8 hub mesh
I am using hub mesh on both a C7 and C8. Are the hubs supposed to show up each others device graph? How can i configure my c7 hub to be a repeater for devices installed on my C8 hub, and vice versa?
Are you referring to zigbee devices?
The hub mesh feature is unrelated to zigbee.
Two hubs can communicate over the LAN to share devices. Each hub’s directly paired devices become virtual devices on the other hub.
I appreciate your response, but im not sure that i understand. Whether zigbee or zwave, is the other hub supposed to show up on a device graph? Once again, i appreciate your help
No, they are two separate Z-Wave and Zigbee networks that know nothing about each other. The graph on each hub only knows about its own network. Hub Mesh is irrelevant, as it is just a way to share devices from one hub to another over your LAN -- no relation to the underlying protocol of the devices at all.
Ok. I got it now. Thank you very much for your reply.
