C4 Hub Unresponsive, Blinking Red Light
Hey all - hope someone can help. I have a C4 Hub that seemingly died today, tried unplugging and replugging but it's just blinking red. It was doing so before I unplugged it as well.
Based on what I could it could potentially be the power brick? Blinking red LED on C-4 Hub(Solved)
Going to order a 1A/5V replacement charger but wanted to see if anyone else can confirm this fix.
Thanks in Advance!
There's only one way to find out, so you'll have to "confirm" for yourself. :slight_smile: As I mentioned in that topic, the C-4 does not use a blinking LED to mean anything. So, if it's happening, the most likely cause is that it's repeatedly turning off and back on, and the power brick or cable would be the easiest culprits (really the only ones if you can't get the hub past this point) to test.
Hey all - just wanted to provide confirmation that it was indeed the power supply.
Interesting failure point that I haven't experienced in other electronics before but it happens!
Thanks,
-Felipe
