Did you order direct from Hubitat? Or from Amazon?
I ordered direct from Hubitat within about 10 minutes of the site going live, and I have yet to receive a shipping notification. Thus, I am just curious what process you used to order your C-8 Pro? Thx
Can the first person to get one up and running post what the free memory is after migration. I'm interested to know if there's a higher starting value. Ta
I've seen this mentioned a bunch of times, but never with evidence.
Seems unlikely that a relatively expensive commercial-grade PoE switch would cause problems, or not fully comply with the PoE standards.
I have a UDM Pro SE powering my C7 with some cheap Chinese POE splitter that cost about as much as a Happy Meal, and it works just fine. If anything, I'd expect cheapo POE splitters to be the problem, not Ubiquity devices.
Of course, this is just a single case and doesn't prove anything one way or another.
More than one person reported issues that were resolved when the POE adapter was remove. Likewise, more than one person reported no problems when using POE.
Would I try using POE with Ubiquity? Yes, but I need to rack all my gear first before I decide if it makes sense. I would also wait to make sure everything is working well before trying it. That way if things started to fail I would only have one change to troubleshoot. The C8 had a lot of issues early on. Between installing a new hub, new firmware, new devices, and a POE adapter it is entirely possible the power was a red hearing.
The issue isn't with the C7's, it's with the C8's , poe spitters, and unifi switches. If you change the switch it's fine. The scenario doesn't apply to the C7's. And everytime we've helped diagnose z-wave issues and that combination has been present, changing to the oem power supply has solved it or using a different poe switch. I use a c8. cheap splitter. and cisco 3750's and do not have the issue. Plug that splitter into my 8 port unifi poe switch and z-wave goes to hell in a hand basket... I hope that makes things a little clearer..
I have a C8, cheap splitter and all Unifi products and don't have a radio issue and that C8 actually sits 1U up from all the Unifi gear in my rack in the garage.
Looks like mine should show up tomorrow - unfortunately I’m going to be about 800 miles away when it shows up, so won’t get to play with it for a few days.
