I’m experiencing a Z‑Wave controller/UI binding failure on my Hubitat Elevation C‑8 Pro. The Z‑Wave Details page is not linking to the controller’s node metadata, and I’m unable to remove failed nodes.
Symptoms:
- Node IDs are not clickable
- Routes never clear
- “Remove” never appears for failed nodes
- Soft Reset + Restore did not resolve the issue
- Z‑Wave radio disable/enable did not resolve the issue
- Full hub reboot did not resolve the issue
- The controller is online, but the UI is not binding to the node table
Hub Information:
- Model: Hubitat Elevation C‑8 Pro
- Platform Version: 2.4.3.176
- MAC Address: *****
- Hardware Version: C‑8 Pro
- IP Address: 192.168.68.98 (Ethernet)
- Hub UID: ****
This appears to be a controller/UI desynchronization.
Could someone from Hubitat engineering please rebind the Z‑Wave controller or advise next steps?
Thank you,
Joe Goldman
