C-8 Pro - local DNS fails after DHCP lease renews
Could I suggest that you go back to static IP? While we will provide the endpoint @gopher.ny said above, there are many things on our plate. If your issue can be solved directly with static IP, as you said above, that would be best. We can't promise that this is going to be top of our priorities.
