I have a Hubitat C-8 that becomes completely unresponsive (no Z-Wave or Zigbee functions, no login page to hub) after about 10 minutes. Network reset does not do anything, and I have tried manually choosing ethernet speed.
@support_team I have an outstanding warranty request and was asked to post here once I was able to power on the hub. Please advise.
No, jumbo frames are not enabled. I had three C-7 hubs working perfectly on the network, and then replaced one C-7 with the C-8. The C-8 worked fine for a few weeks, then stopped working. I went back to the original C-7 and now have the three hubs working fine on the network. It appears there is something wrong specifically with the C-8 hub.
Did you migrate a C7 to the C8 when you originally set it up?
If so, Have you tried resetting the C8 ad running the migration again? Have you tried resetting the C8 and testing basic functions with a clean database?
How was the C8 being powered? Supplied block or other source / PoE splitter?
Yes, I migrated from the C-7 to the C-8. I did do a hard reset via diagnostic tools and a manual network reset and migrated back to the C-8. It appears to now be operational, but the LED is blinking green/red.
The C-8 is connected via supplied block. Hub is on ethernet, static IP is set in the hub.
So everything works now except you have the flashing LED?
A few other people have seen this issue, after the next update release (they are adding more logging) you could update and then join in this other thread and see if they want your hub ID to check the logs.
