My C-8 suddenly stopped communicating a few days ago and I only get the blue LED when I re-boot. If I do the 8 second reset, the LED briefly blinks green then blinks red then goes back to blue. I was going to run the diagnostic tool by entering the former ethernet address with:8081, but got nowhere there either. I'm not sure what to do if I don't have the right ethernet address for that matter. I would love some hep.
Or if that's not working you can try this tool https://angryip.org/ to scan the entire LAN
You may also want to try a network reset on hub using the hidden button on the bottom of it, as shown in the docs here: Network Setup | Hubitat Documentation
Thanks for those great links. I tried the MAC scan and the in findmyhub as well as the Ethernet scan but no luck. It's unclear if angryip.org works with Windows. I says it does in the description but it does not have that selection in the OS field. I only see Ubuntu, Debian, SLES, Red Hat, Docker and VMWare ESXi. Does one of those work on Windows?
I did try the hidden reset early on and it goes to blue, then green blink then red and then permanently back to blue.
Thanks for the Windows link everyone. I got AngryIP installed and scanned the net. I have a lot of things on my home network but believe I found the hub and it matched the IP address that my.hubitat.com listed as recent, but it is unresponsive to opening a web page there. I can ping it though and obviously it responded to AngryIP so it's not totally dead, but it does not seem to be booting all the way. I actually have 2 Hubitat's on my network and I can get access to the other one no problem, but my primary Hubitat C-8 is still unhappy.
Any ideas on how to breath some life into it now that I found it?
Yes, of course. Thank you! That did work and I can get to the diagnostics page! Excellent. I'll download some backups, try a re-boot and then maybe update to latest SW version
Thank you all. That worked and the Soft Reset to an older backup works. Thank you very much for spending your valuable time assisting me. Very much appreciated.
