I am having an issue with Z-Wave Repair on the C-7.
I have some devices that are a ways away from the hub. I had no problem adding these devices, but when I do a Z-Wave repair, the repair fails when it gets to one of these devices. Once it fails on one device, it fails for all subsequent devices. I've included an example log file below.
I've removed 3 devices so far (0x32,33,34) to get the repair to go a little farther, but the device it's failing on at the moment (0x36) is a critical device, so I don't want to remove it from the network.
The very interesting thing is that while the log says that the hub it is "updating neighbors" and "requesting device routeList", there are actually no packets being sent by the hub to the device. In the example, the hub actually sent no packets at all between 17:12 and 17:32.
Once the issue occurs, all the hub makes no actual attempt to contact any of the devices that follow in the node list.
If I perform a refresh on each of these devices, they will change from "UNKNOWN" to "OK". And the devices also function as expected (report status, controllable, etc.)
Is anyone else experiencing this problem?
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:45:50.230 errorZ-Wave Node 38: Repair failed, the maximum retries have been exceeded
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:44:20.187 traceZ-Wave Node 38: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:42:50.151 traceZ-Wave Node 38: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:41:20.115 traceZ-Wave Node 38: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:39:50.078 traceZ-Wave Node 38: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:38:20.042 traceZ-Wave Node 38: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:36:50.006 traceZ-Wave Node 38: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:35:19.970 traceZ-Wave Node 38: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:33:49.933 traceZ-Wave Node 38: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:32:19.899 traceZ-Wave Node 38: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:32:19.888 traceZ-Wave Node 38: Repair starting
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:30:49.840 errorZ-Wave Node 37: Repair failed, the maximum retries have been exceeded
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:29:19.799 traceZ-Wave Node 37: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:27:49.755 traceZ-Wave Node 37: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:26:19.738 traceZ-Wave Node 37: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:24:49.704 traceZ-Wave Node 37: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:23:19.674 traceZ-Wave Node 37: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:21:49.645 traceZ-Wave Node 37: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:20:19.614 traceZ-Wave Node 37: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:18:49.576 traceZ-Wave Node 37: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:17:19.557 traceZ-Wave Node 37: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:17:19.552 traceZ-Wave Node 37: Repair starting
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:15:49.518 errorZ-Wave Node 36: Repair failed, the maximum retries have been exceeded
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:14:19.466 traceZ-Wave Node 36: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:12:49.429 traceZ-Wave Node 36: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:11:19.399 traceZ-Wave Node 36: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:09:49.377 traceZ-Wave Node 36: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:09:41.164 warnZ-Wave Network responded with Busy message.
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:09:31.151 warnZ-Wave Network responded with Busy message.
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:08:19.334 traceZ-Wave Node 36: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:06:49.320 warnZ-Wave Network responded with Busy message.
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:06:49.302 traceZ-Wave Node 36: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:05:19.296 warnZ-Wave Network responded with Busy message.
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:05:19.283 traceZ-Wave Node 36: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:03:49.265 warnZ-Wave Network responded with Busy message.
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:03:49.248 traceZ-Wave Node 36: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:02:19.228 warnZ-Wave Network responded with Busy message.
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:02:19.220 traceZ-Wave Node 36: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:02:19.214 traceZ-Wave Node 36: Repair starting
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:02:13.286 traceZ-Wave Node 35: Repair is done.
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:02:13.273 traceZ-Wave Node 35: Repair is adding return routes
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:02:12.549 traceZ-Wave Node 35: Repair is deleting routes
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:02:11.284 traceZ-Wave Node 35: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:02:04.192 traceZ-Wave Node 35: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:02:04.188 traceZ-Wave Node 35: Repair starting
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:58.836 traceZ-Wave Node 31: Repair is done.
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:58.823 traceZ-Wave Node 31: Repair is adding return routes
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:57.958 traceZ-Wave Node 31: Repair is deleting routes
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:57.542 traceZ-Wave Node 31: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:49.175 traceZ-Wave Node 31: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:49.162 traceZ-Wave Node 31: Repair starting
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:44.913 traceZ-Wave Node 30: Repair is done.
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:44.909 traceZ-Wave Node 30: Repair is adding return routes
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:43.782 traceZ-Wave Node 30: Repair is deleting routes
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:43.365 traceZ-Wave Node 30: Repair is requesting device routeList
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:34.149 traceZ-Wave Node 30: Repair is updating neighbors
[sys:1](http://hubitat.cococafe.com/logs#sys1)2020-07-30 17:01:34.143 traceZ-Wave Node 30: Repair starting
