I know there are other threads on this topic, but they seem to reference older versions so I want to start a new thread.
I'm trying to migrate a C-5 to a new C-8 Pro, and every restore fails with "Internal error occurred while restoring backup." with all components marked Failed. I've opened a support ticket too, but wanted to see if anyone has hit this.
Setup
- Source: C-5 on 2.5.2.129. Today I switched it from legacy Z-Wave to Z-Wave JS (Settings > Z-Wave Details > Switch to ZWave-JS). All 10 Z-Wave devices completed their interviews and work normally on the C-5.
- Target: brand-new C-8 Pro on 2.5.2.129, Z-Wave JS 15.29.0 (firmware 7.18.1), empty, wired Ethernet. The C-5 is powered off during attempts.
What I've tried
- Older cloud backup (C-5 on 2.5.1.183, legacy Z-Wave) with all components: rejected with "This backup contains legacy Z-Wave data, but this hub is using ZIP Gateway" (same after switching the C-8 Pro to Z-Wave JS). That's why I converted the C-5 to Z-Wave JS.
- New cloud backup (C-5 on 2.5.2.129 with Z-Wave JS, new "full backup" format), all components: Internal error (twice).
- Same backup without File Manager: Internal error.
- Same backup without File Manager or Z-Wave (database + Zigbee only): Internal error.
- Local full backup (.tar.gz) of the same, uploaded through Restore on the C-8 Pro: Internal error. The archive looks intact (database, File Manager and Z-Wave JS data present, checksums match the manifest).
Nothing shows up in the C-8 Pro's logs. Has anyone gotten past this, especially a C-5 that was converted to Z-Wave JS? I'd really like to avoid re-pairing everything.
