Outside of the power adapter, it is identical. The frequency used by the zwave radio in the C-7 can be set by the end-user. Therefore, the same hardware is sold worldwide.
You can use any compatible USB adapter that supports at least 1A load at 5VDC.
Ah did not realise that. Makes sense now though.
Guess I could also use a travel adapter plug as have plenty of those lying around.
Will place the order now
Be aware that buying from EU countries takes a lot longer to arrive than they used to. Things can sit in customs for up to a month, and you don't know what customs charge you may end up paying. I am not prying into why you don't want to use Vesternet but you may like to think about whether you could reconsider. Even the ebay ones I saw were coming from outside the UK.
No reply yet but it seems this is a feature (or quirk depending how you see it) of WordPress.
The site is built using WP.
Found plenty when I googled but this is best explanation:
"This is to notify your customers that they can order the product even if it’s out-of-stock. If you prefer not to show the “can be backordered” message, choose “Allow” under Products > Edit Product > Product Data > Inventory > Allow backorders?"
Sound a bit nuts to me but thats what it appears to be.
Cannot fault the service from Smart Home Alarms.
They replied to my email at 9:20am Monday morning.
Confirmed the C7 was in stock and were about to dispatch it (email confirmation of dispatch arrived a few minutes later).
I had chosen the cheapest shipping option and it arrived Tuesday morning at 10:30am (so next working day delivery).
Recommended.
