Button Controller not behaving normally
I just did a soft reset on the hub and in trying to get things going again I'm running into this issue with button controller.
When I push CLICK TO SET under Define Button Action, the pull down menu is too short to read anything, and even if I just try clicking a portion of the square for "pushed", then I get Unexpected Error.
Does that switch support "buttons"? I know the zooz & Inovelli switches do.
What type of switch is it? If I have 1 I can try to setup and see
yeah definitely, its a inovelli red2, I program the buttons all the time. but now you got me thinking maybe it has something to do with the driver im using since I did a soft reset on the hub. ill check to make sure im running the non stock driver and update this thread.
Confirmed this was user error on my part for not loading the new Inovelli switch/dimmer driver.
