Button Controller 5.1 - Track Dim - Inovelli + Philips Hue
I'm trying to set the Track Dim so that the dimmer setting change on my Inovelli Red dimmer is sent to my Philips Hue light, but nothing is changing.
So I set the action on pushed 6, which is when I release the dimmer increase. I see in the log of the dimmer level set to 66 for example before the pushed 6 event, yet the light doesn't change. But the order doesn't matter since even if I press it again, no light output change on my philips hue lights.
So could this be fixed, or do I have to create some other rules when I have to set a variable for every single light I have (I have about 18 of them), so to use variable instead of the track dimmer ?
If you want the hue bulb to match the dimmer try the mirror app.
