No, they are different events. You'll need to,subscribe to each one (or to everything, but I would not recommend that approach since you'll likely also get things like battery events that are not necessary for your app).
As I stated, I am not going to do that. But wondering how it would be done. There doesn't appear to be any atribute to subscribe to that would subscribe to any event from the button device. Just leaving the atribute blank throws an error.
EDIT:
According to the docs, this is aceptable:
void subscribe(DeviceWrapper device, String handlerMethod, Map options = null)
I tried
subscribe(testButton, testHandler)
subscribe(testButton, ,testHandler)
subscribe(testButton, "", testHandler)
None work.
Figured it out:
subscribe(testButton, null, testHandler)
Just pointing out a subtle difference since that wasn't a variant I saw mentioned above.
In any case, that doesn't appear to be working for me either. I'm not sure why, as there appears to be hub code that should handle it. But passing null for the attribute, as you discovered, or providing an empty Map instead of null for the options (e.g., subscribe(testButton, "testHandler", [:]) — making it use a different signature) both work in my testing.
