Since I updated to 2.4.1.151 all 4 of my Zigbee Aqara Temperature devices stop getting temperature updates. I still get Humidity readings.
I have readded the devices with no luck.
What is the model number of your sensors, and which driver is being used? Can you turn on debug logging and see if temperature data is being sent, but not being parsed correctly by the driver?
Was out for the day and when I came back home, I saw a few other Zigbee devices not reporting at all and rejoining them did not fix them either. I didn't see any log errors when I checked this morning and just a bit ago.
Unless someone else reports Aqara or other Zigbee errors with the new update I will assume I have some other Zigbee/device issue.
I have rolled back to v 2.4.0.151 and restore the last database and so far, no problems and I will be checking the next few days for issues.
The temp reporting issue for these is fixed in 2.4.1.154
