[BUG] ZooZ Power Switch error on 2.1.4.119
After updating to 2.1.4 I'm periodically seeing the following error in my logs:
dev:4502019-08-22 10:14:36.478 pm info Shed Dehumidifier voltage is 123.204 V
dev:4502019-08-22 10:13:23.854 pm error java.lang.NumberFormatException: null (parse)
dev:4502019-08-22 10:10:36.586 pm info Shed Dehumidifier voltage is 123.286 V
dev:4502019-08-22 10:00:36.548 pm info Shed Dehumidifier voltage is 123.368 V
dev:4502019-08-22 09:59:24.040 pm error java.lang.NullPointerException: Cannot invoke method and() on null object (parse)
dev:4502019-08-22 09:57:52.527 pm info Shed Dehumidifier energyDuration is 10.11 Days
dev:4502019-08-22 09:57:37.790 pm info Shed Dehumidifier voltage is 123.286 V
This is using the built in device handler.
What firmware version is shown in the data section of the device details?
If you use the "Show Past Logs" option in logging and filter by that device, do you see any of those errors from before the hub update?
firmwareVersion: 1.2
I can't get back that far in Past Logs so I don't really see anything else. I haven't seen the errors since doing the update to 2.1.4.125, guess I'll just keep an eye on it.
