I connected a SmartThings button via Hub Mesh yesterday and it did the same as you described. It was going active every 1m 10secs.
On the hub it was paired with nothing was seen, but on the remote hub it was activating.
If memory serves me I think I disconnected it from being available on the remote hub, it went OFFLINE and when I reconnected it everything was OK.
Might be worth a try.
What do you mean by this? I have 4 hubs and just upgraded yesterday and wanted to use hub mesh instead of HC. Modes are important to sync across all 4 hubs and thought hub mesh would handle this. If this doesn’t work you’d be saving me time this week.
Thanks @gopher.ny. I was planning to dismantle hubconnect this weekend and setup hub mesh and decided to test sharing a button with my dev hub yesterday. This is a SmartThings button that hasn’t been touched since I set this up yesterday afternoon. Here is the dev hub receiving updates via hub mesh where 395 events have been logged:
@gopher.ny are you aware of an issue with modes syncing across multiple hubs as mentioned above? Unfortunately @tuffcalc never replied with more details on the issue mentioned above.
@tuffcalc@gopher.ny just posted a new build that should correct the button issue you reported. In my quick test, all is well in my dev hub. More details here:
