I have a variable shared through hub mesh. Type string, not sure if that matters. I added it to a rule and it will not provide me with an entry box to put a value in. Am I doing something wrong or is this a bug?
It almost seems like a browser thing... or not
But, would you see if it works as expected for a Hub Variable not shared through Hub Mesh?
That may shed some light on where this fail is.
Thanks. Pretty strange. We will look into it.
I could reproduce this, but only with that particular variable name
Will figure it out.
Curious - spaces maybe? Hyphens? Thanks.
"/" character was the culprit. Fix coming in the next build.
