BUG Simple Rule Turn on lights Sunset -30m (executed @ ~ -90m)
So, I set up a 'simple' rule some months ago (post switch to EDT), turn a few lights on all of the time at sunset -30m. This worked fine UNTIL TODAY.
Today I come in at c. 420p EST and those LIGHTS are ON already. Sunset is still an hour AWAY.
Look at log, they turned on at c. 354p EST (or ~ -90m BEFORE sunset).
Looks to me like there is some kind of EDT/EST/timezone bug.
Location is CORRECT.
HE time is CORRECT.
Cannot explain otherwise, I see no errors in the brief glance that I gave to the logs to check the time they came on. AND it is ONLY the lights that this simple -30m before sunset rule APPLIES to that turned on...
[EDIT]
I have a VERY SIMPLE setup ATM of c. 15 zigbee lights (IIRC), so it's not a case of an overloaded 'server' going ape----...
Also might merge with the other identical topic...
[/EDIT]
[EDIT2]
I have the Alexa skill and Google home integration installed.
I have the dashboard and simple Android 'app' installed.
simple rules machine, rules machine, mode manager, and groups and scenes...
fw v. 2.1.6.113
[/EDIT2]
[EDIT3]
This
is the suggested merge target... thanks
[/EDIT3]
