[Bug Report] Stack overflow when deleting hub variable connectors
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
Hub: C-8 (model 000D), firmware 2.5.0.143
Summary: Removing a hub-variable connector device throws a java.lang.StackOverflowError in the built-in "Variable
Connectors" component driver's childRemoved() method. The connector is removed, but the child device's uninstalled()
fires ~10 times (recursion) before the stack overflows. It happens through the stock UI — no custom app involved.
Repro:
  1. Settings → Hub Variables → add a String variable repro_var, initial value y, save.
  2. In that variable's row, click the Connector control to create its connector device.
  3. Devices → open the repro_var connector device → Remove → confirm.
  4. Check Logs:
    WARN dev: repro_var uninstalled repro_var (×~10)
    ERROR dev: Variable Connectors java.lang.StackOverflowError: null on line 30 (method childRemoved)
Impact: Removal succeeds, but every connector deletion dumps a StackOverflow + a flood of uninstalled lines into the
log. Looks like childRemoved() re-enters child teardown recursively.
