[BUG REPORT] Lock Code Manager when using Enable and Disable on Date
When using Lock Code Manager using the option for Enable "Enable and Disable on Dates," the code fails to activate. This happens 100% of the time. I am using Kwikset locks, and I have no issues with other code options in the LCM app. Screenshots provided from the mobile app, where user Kristin Leceuta is the one at issue.
To reproduce:
  1. Go to add a code
  2. Give a name, code, and select a lock.
  3. Open the user code options
  4. Select "Enable and Disable on Dates"
  5. Enter a date and time range, make sure disable is after enable.
  6. After selecting done, select the button "Update user code options"
  7. Select Next.
Now, the user will show up in the list, showing "Enable and Disable on dates" which is good. Here's what happens next:
  1. When the Enable date and time is reached, the user will disappear from the existing users list.
  2. The user's code will not work.
  3. When the Disable date and time is reached, the user will appear in the existing users list and show as "Disabled"
Is this bug in the list to be remediated?
EDIT: I would post images, but using the insert image button results in the error "An error occurred: Sorry, you can't embed media items in a post."
You can post images and links if you join the hub owners group.
