nclark
February 16, 2020, 9:48pm
1
ok, just went in my office and see my lights turn on when they clearly should not have during daytime based on sunset-sunrise.
So here is the condition...
It is true as you can see by the (T) after the condition, yet sunset is at 17:21 - 30 minutes, so should not be true until 16:51.
Yet as you can see in the logs, the lights at the printer turned on 16:30
I checked the hub time in the settings menu / hub details and the time is right...
Would like to help and find the problem but not sure what else I can check to find out why this is happening?
nclark
February 16, 2020, 9:53pm
2
BTW, this is not a new rule and has not been modified since last Thursday, was working fine Thursday night and also last night when I was in the office during sunset hours (before and after sunset).
zarthan
February 16, 2020, 10:40pm
3
You should probably post your whole rule. There may be other reasons that a rule doesn't run reliably.
Check the System Events to make sure the sunrise and sunset times for today were set yesterday.
nclark
February 17, 2020, 12:56am
5
Here are the system events for last 48 hours...
nclark
February 17, 2020, 12:58am
6
We can clearly see that the condition is set to True on that line when it should not be, so has nothing to do with the logic of the rule.
Waiting until tomorrow if it behaves the same, I also created another dumb rule just to see if it will do the same in the other rule.
system
Closed
September 23, 2022, 10:58am
7
