[BUG REPORT] 2.5.2.135 Sonos Integrator not capturing/restoring proper Sonos speaker state after TTS
Hi -
Been working w/ the new Sonos Integrator under platform release 2.5.2.135 and testing its TTS capabilities.
The integration does not appear to be capturing and restoring the proper speaker state.
Here's the scenario -
  1. I have a speaker (Morning Room-) that was originally playing a track.
  2. I paused/stopped the track in the Sonos app.
  3. I then "speak" a TTS message (It is medicine time! Did you take it?) to the speaker within Rule Machine.
I "expected" the text to be spoken, and the speaker to remain in its paused/stopped state.
What happens is that the speaker begins to play the previously paused/stopped track where it last left off.
The problem occurs no matter which method I use to output the text. i.e., notification devices, TTS, or music player devices. I even tried sending the commands as parameters to several of the device attributes w/ no joy.
Note that this problem does not occur in the 3rd-party "Sonos Advanced Controller" app.
Here are couple of screen shots showing my setup:
Thoughts?
Thanks!
Peter
One other question -
I don't quite understand what the Habitat general strategy is regarding the "absorption" of user developed application and/or driver capabilities.
From a consumer standpoint, I think most folks want to use built-in feature-functionality as much as possible as it typically stands the best chance of growing and being supported by the product and company long-term.
But -
I also understand (and very much appreciate!) the ability to add and use 3rd-party developed capabilities. It's extremely valuable for those users that have boundary use-case scenarios.
The Hubitat-Sonos integration has needed work for a long time.
During this period Daniel Winks (many thanks!) developed the Sonos Advanced Controller code base.
In the case of the Sonos Integrator, is the goal to absorb and replace the Sonos Advanced Controller functionality (as the direction appears) or to simply co-exist where the Integrator will only ever contain a functionality subset?
Thoughts?
Peter
Yes this is very frustrating. Hubitat support have stopped responding to anything about issues with the new Sonos Integrator. I've had no response for about 7 days now.
