This doesn't work...the lights come on, but stay on and never turn off (with the rule constantly showing as active).
I went so far as to trigger the motion sensor, and then "hide" from it...I waited over 5 minutes and the lights did not turn off (supposed to turn off 1 minute after motion goes away).
The routine setup in the Motion and Mode Lighting App works fine.
I probably should have asked the question differently...I know how to remote access, but where do I go to get the logs? When I click on the "gear" icon under the rule I don't see that option.
OK, it appears the import is not setting up that time restriction correctly. I will look into that. In the meantime, please remove this instance and just create it from scratch.
I just set up a Motion Lighting with the same time restriction, and it did import correctly. So I don't really know what happened to this one above.
