I have the following RM-4 rule that notifies me when the temperature in the refrigerator gets too high. However, I seem to be having an issue with it. Here is the rule:
As you can see from the rule, the actions evaluating the temperature shows true when it definitely should be false. Current temp is 41.61 and is less than 50 but is showing TRUE and the rule fires.
What am I doing wrong here?
EDIT: When I first set it up and it automatically created the trigger event, it populated the conditions and I noticed it did not show the >= 50. If I create another condition with the >= 50 condition, the rule evaluates as FALSE as expected. Isn't creating another condition in this scenario redundant?
Scott
