JoeJ
February 21, 2022, 4:05pm
1
I don't know if this is the right place to post bugs, but here goes.
The Driver for the Leviton DZHD Dimmer has a "Turn On Indicator" preference that does not appear to work. Setting one of the three values does not change the device plus I see no log messages when this is done.
csteele
February 21, 2022, 4:15pm
2
Is this a duplicate post??
I'm using the Basic Z-Wave Tool to send an option to a Leviton DS6HD dimmer. The option sets the state of the Indicator LED, it is Command 7, 1 byte, with either 0 (always OFF), 254(Status Mode), or 255( default, Locator mode).
[parm_panel]
I'm sending 255 as the data and it acts like I'm sending a zero. Sure enough the logs show I AM sending a zero.
[log_panel]
Anyone have trouble with the basic tool sending the wrong data? Or am I doing something wrong.
Seems there's helpful responses there.
JoeJ
February 21, 2022, 4:18pm
3
No, this is a different issue. Yes, using the Z-Wave Basic Tool is a work around for this, but this problem is in the official Leviton DZ6HD Driver.
csteele
February 21, 2022, 4:49pm
4
OK, I buy that...
@bcopeland
My Zniffer confirms. Doesn't matter what selection is made, the packet to the device has Zero as the value. (parm:7, size: 1, value:0)
Found the problem.. Fix will be in next release
