[Bug] Enum Input in Setting Doesn't Show Saved Selection
Was just working on a driver and ran across this issue. I'm not sure if its a 2.0.8 but or existed before.
With the following input, if I select multiple items and click save preferences, the updated screen does not show the currently selected items in the input.
input(name:"volumeStream",type:"enum",title:"Volume Stream",
    options:["0":"Voice Call","1":"System","2":"Ring","3":"Music","4":"Alarm","5":"Notification","6":"Bluetooth","7":"System Enforced","8":"DTMF","9":"TTS","10":"Accessibility"],
    defaultValue:["3"],required:true,multiple:true)
Multiple in devices is not supported at this point. It's on the list.
Ahh... ok. I'll change it to single for now I guess.
It does work though code wise. The setting variable is set properly. It just doesn't show on the device page what is selected. But good to know.
+1 for this feature request.
I had this question previously and you even responded. Hopefully it can be added/fixed at some point. It works in apps as you pointed out.
