Attempting to enter email confirmation code into the Hubitat iOS app on my wife's iPhone running latest version of iOS.
Issues:
-The screen behind the keyboard doesn't scroll up or down
-Clicking Continue from the Email field does not advance to the next input
-Clicking Return from the Code field does not submit the form
If you're using Safari, tap the little A/big A symbol next to the URL, and you can shrink the page, or request the desktop version. Perhaps one of those will help.
There is an option in the iPhone settings to turn off the word suggestions right above the keyboard. It looks like, from your photo, that if you do that you may be able to get the password entered. Then you can turn that back on.
To toggle that it's Settings -> General -> Keyboard and then look for Predictive and toggle that. Hope that gets you going.
I'm seeing this in Android too running the latest version of Firefox. In Chrome when you attempt to scroll, the top & bottom browser bars disappear and you can see everything.
Galaxy S7 running Android 8, latest versions of Firefox and Chrome
I had the same problem and was able to get around this bug by doing the following:
On your iPhone go to Settings >Display & Brightness >DISPLAY ZOOM > select Standard and then select Set. Note you have to scroll down to get to "Display & Brightness " and "DISPLAY ZOOM"
It will respond "Changing Display Zoom will restart iPhone" tap on Use Standard!
Now you can see the confirmation button after you enter the code. When you are done you can set the display zoom back to Zoomed.
