Bubs off, not responsive, hub seems OK
This evening I noticed all my exterior lights were out. They're all Innr zigbees, all the sockets power goes through a bank of three wall switches inside the front door. I flipped the switches off, and then on again expecting light. There was light, but not much. About 50% (they are color dimmable bulbs) brightness.
Unfortunately none would respond to their device settings in the Hubitat app on my phone or the web page in my computer browser. I rebooted my Hubitat C-8 a couple of times, but no change, they just don't respond at all.
Any likely cause of this that I should check? The problem with this system is that when I get it working right, I don't touch it for months and then it's completely strange to me in trying to figure out how I set things up. It's only 7 bulbs,
So I swapped out the "smart" bulbs for dumb bulbs. It's getting late and I'll think better after a night's sleep.
I'm tempted to reset everything and start from scratch, but I'd really rather go to a movie tomorrow.
Thoughts?
There anre options under “Settings -> Zigbee Details” to Reboot the radio and Rebuild the network. Did you try those to see if it might help?
You could just reset the bulbs and rejoin them. Don’t delete them; they will slot back in like it never happened
Yeah, basically I took everything apart and then hooked things up "in order" again. Things worked until I found two bulbs that were still unresponsive, and on top of that would not reset!
Weird that two would simultaniously "die" like that?
Anyway, I configured two new bulbs and installed them and everything is working again. I learned, back when Macintosh computers used SCSI (Scuzzy) cables for connecting drives and other components, that some electronics are part voodoo, and there's nothing you can do about it besides just sacrificing chickens.
No, and I'd already started my rebuild when I read this. Thanks for the info, will keep it in mind for the future.
